Advisor
Advisor
XML parser for TCL
Guys,
I need to parse an xml file from within a tcl script. Reading around on the web it seems like tDOM is the dominant package for parsing xml in tcl but "package require tdom" returns "can't find package tdom".
Typing "package names" at the Vivado TCL prompt returns a long list of packages but none seem to be related to XML.
Does anyone know how to use an xml parser in Vivado TCL?
DSP in hardware and software
Mentor
Mentor
Re: XML parser for TCL
Ok,  I think I have a solution for this..    This solution was run on Kubuntu 14.04, and probably needs a lot of modification for Windows 7, or other operating systems.
first download tDOM from github
git clone https://github.com/tDOM/tdom.git
sudo apt-get install pkg-config tcl-dev
cd tdom/unix
../configure
make
sudo make install
Now at this point, you should see " Install pkgIndex.tcl /usr/lib/tdom0.8.3" in the output during installation (this version number will probably change in the future).
Open your Vivado GUI, and type this in the TCL console:
puts [lappend auto_path "/usr/lib/tdom0.8.3"]
Now you can type "package require tdom", and see this:
0.8.3
To avoid having to modify $auto_path everytime, set this in your .bashrc
export TCLLIBPATH=/usr/lib/tdom0.8.3
Although this has the property of putting tdom at the FRONT of the directory search paths, rather than the end, so be aware of this difference.
I used to be a Xilinx FAE,  so I'm happy to know I can still fix problems like this.....
@pedro_uno What you want do?
you can parse the file and make some changes using simple open and read in vivado tcl console as well.
set fd [open "/tmp/testdata.xml "w"]
file4
% set a [read $fd]
-Pratham
Advisor
Advisor
I want to be able to navigate the XML tree in my TCL script.
XML parsers read the xml input and create a proper TCL list.  TCL lists are designed to contain this sort of hierarchal information because TCL lists can contain lists. These techniques are very mature and common.
The tDOM library seems to be the richest but there are other lightweight packages.  Look here for a discussion of XML with TCL.  http://wiki.tcl.tk/1948
It looks like the two technologies evolved together.  In fact, EDA information often exists as XML files. What does Xilinx itself use to parse XML in TCL?  I'm sure that would be sufficient for anything I need to do.
    Pete
Did you ever find the answer to this?  I am in the same boat as you.
Ron
Anonymous
Not applicable
Ron,
No, I have not made any progress on this. I did not want to push too hard if I was the only person interested.
Maybe it is time to ask my FAE. He has quickly found the answer to several things that stumped the forums.
I'm thinking that Xilinx must have some kind of XML parser built into their standard xTCL interface because so many of their files are in XML format.
  Pete
Mentor
Mentor
cd tdom/unix
../configure
make
sudo make install
0.8.3
Advisor
Advisor
Thanks man, that is a really good solution for me since I nearly always use Vivado under Ubuntu.
