Visitor koen.lostrie
automated synthesis with custom VHDL packages and libraries
Dear all,
I've written a couple of automated tcl scripts to synthesize VHDL designs that students hand in. Sometimes they use custom packages and libraries though, which of course results in errors during synthesis.
Is there a way to find out which packages and libraries they use with tcl commands, knowing they only hand in their .vhd and .xdc files?
When a student for instance uses a library "digital" in which he compiled a package "globalSignals", how can I extract this information using tcl commands?
Or, if this is not possible, is there a file in their project directory they should hand in as well, so that my script can synthesize this?
Thanks for your expertise.
Koen
Re: automated synthesis with custom VHDL packages and libraries
"I've written a couple of automated tcl scripts"
So you are an automata. AI is here!
No, TCL is not for browsing and finding stuff in vhd or xdc files. forget about that.
I would simply read them. Being student assignments it shouldn't be that much.
Text editors have good find tools. Notepad++ is very good at that. Millions of programmers use it since 20 (?) years ago and is still good. There must be a reason.
Otherwise, if really want to "automate" things, I suggest a Python script... the latest millenial fashion. But I wonder if it will take longer than manually. Also, wherever there is software there are bugs.
Thank you for your quick reply.
I agree that reading them manually solves this problem... if there weren't over 70 students that hand in 8 or 9 excercises... multiple times... and expect feedback on them every week.
So I hope you understand my need for automation ;-)
I do read their (latest) code manually and discuss this with them, but this is easier when you already know if the code is working and got approved by my automated testbenches.
The aid of other script languages is of course a good solution. I was hoping for a tcl command, which avoids writing another script, but alas ;-)
Thanks again!
Scholar brimdavis
@koen.lostrie   "Is there a way to find out which packages and libraries they use with tcl commands"
The get_files and report_compile_order commands have a  -used_in synthesis option which might help, e.g.
   report_compile_order -used_in synthesis
The following thread gives an example of finding libraries for simulation:
   https://forums.xilinx.com/t5/Simulation-and-Verification/finding-simulation-libraryes-from-IP/m-p/858734/highlight/true#M22295
set ip_files [get_files -compile_order sources -used_in simulation -of_objects [get_ips <ip_name>]]
foreach file $ip_files { puts "[get_property LIBRARY $file] $file" }
-Brian
Dear brimdavis,
Thank you very much for your input. However this is not a solution for me, since this only works for an IP block, where the library information for each source file is included in the IP block. The students hand in separate VHDL source files, which all get the default library xil_defaultlib associated with them.
I appreciate your input, but I'm afraid I will have to use some other script to parse their code in advance (as archangel suggested) and use this in my tcl script.
Thanks again!
Scholar brimdavis
@koen.lostrie   "this is not a solution for me, since this only works for an IP block"
The report I suggested is *NOT* limited to IP blocks (although it can be used that way); report_compile_order will by default list library mappings for all the files in the project that are -used_in the selected flow.
So as long as your students are using Vivado for development, before turning in their project they'd first run this:
report_compile_order -used_in synthesis -file ./compile_order.rpt
And then include the output file  compile_order.rpt  with their source files. An example compile_order.rpt,  snippets with highlighting:
INFO: [Vivado 12-3442] The output from report_compile_order is primarily targeted for human readability and ease of use. The 'get_files' command, with the -compile_order and -used_in options, produces this same information in a format that is better suited for automated scripts.
Source compile order for 'synthesis' with fileset 'sources_1' in source management mode 'All':
Index  File Name            Used_In      File_Type  Library         Ngc Wrapper  Full Path Name
1      y1_constants.vhd     Synth & Sim  VHDL       xil_defaultlib  No           C:/Projects/yard/hdl/cores/y1a/y1_constants.vhd
2      y1a_config.vhd       Synth & Sim  VHDL       xil_defaultlib  No           C:/Projects/yard/hdl/cores/y1a/y1a_config.vhd
3      addsub.vhd           Synth & Sim  VHDL       xil_defaultlib  No           C:/Projects/yard/hdl/cores/y1a/addsub.vhd
4      barrel.vhd           Synth & Sim  VHDL       xil_defaultlib  No           C:/Projects/yard/hdl/cores/y1a/barrel.vhd
10     debounce.vhd         Synth & Sim  VHDL       debounce        No           C:/Projects/yard/hdl/common/debounce/debounce.vhd
11     debounce_pkg.vhd     Synth & Sim  VHDL       debounce        No           C:/Projects/yard/hdl/common/debounce/debounce_pkg.vhd
12     debounce_tick.vhd    Synth & Sim  VHDL       debounce        No           C:/Projects/yard/hdl/common/debounce/debounce_tick.vhd
Unless I misread your post, you were looking for an automated way of finding the source file library mappings (packages should 'just work' as long as you've placed the student's files in the correct libraries within your automated scripting), which the above report should enable.
EDIT: There are a number of different ways to figure out the library mappings; another method would be to have the students include their Vivado project file (.xpr) extension, which is an XML file that also includes the filename and library information
-Brian
@brimdavis My apologies, but I thought you suggested I ran the report_compile_order command on their vhdl files.
Out of the two solutions you propose, I would certainly select the .xpr option for the simple reason that it should not only be a "fool proof" solution, it should be "student proof" (which is the next level up) ;-)
At the moment, the only thing they must hand in is all their relevant .vhd files and their .xdc file. You'd be surprised how many students fail this very simple task (.xci files, vhd code pasted in .txt or .docx files, .xpr files,...). Having them open the Tcl console, type in a command, find the generated file and hand it in will cause me much more problems, holding their hands and practically typing it in for them. I could have an entire off topic discussion/rant here about teaching students (especially first year students) to read walkthroughs and instructions, but I'm afraid that wouldn't achieve much here ;-)
Your second solution, the .xpr file is definitely an option which I'll look into. In the meantime, I've written a small parser script in Tcl (see below) which works so far without changing the file types they have to hand in. If I run into problems with that, I'll definitely use the .xpr option, but I will have to do it from the beginning of the semester (next year) or it will definitely confuse them.
Thanks a lot for your input!
The piece of Tcl script:
# search all vhd source files for custom packages/libraries
# first find custom packages
set files [glob ../*.vhd]
set customPackages {}
for {set i 0} {$i < [llength $files]} {incr i} {
  set fh [open [lindex $files $i]]
  while {[gets $fh line] != -1} {
    if {[regexp -nocase {package[ \t\r\n]+([^ \t\r\n]+)[ \t\r\n]+is} $line fullMatch packageName]} {
      puts -nonewline "Custom package $packageName found in file: "
      puts [lindex $files $i]
      lappend customPackages $packageName
      set packageFile($i) $packageName
  close $fh
puts "Custom packages found: $customPackages"
# Then find in which libraries these packages should be compiled
    for {set j 0} {$j < [llength $customPackages]} {incr j} {
      set packageName [lindex $customPackages $j]
      if {[regexp -nocase "use\[ \t\r\n\]+\(\[^ \t\r\n\]+\)\[ \t\r\n\]*\.\[ \t\r\n\]*$packageName\[ \t\r\n\]*\." $line fullMatch libName]} {
        set packageLib($packageName) $libName
  close $fh
# read in the source files from the upper directory
# custom packages should be associated with the correct library
  set curFile [lindex $files $i]
  if {[info exists packageFile($i)]} {
    set curLib $packageLib($packageFile($i))
    puts "Reading $curFile to custom library $curLib"
    read_vhdl -library $curLib $curFile
  } else {
    read_vhdl $curFile
read_xdc [ glob ../*.xdc ]
