Visitor skidaddytn
command line vivado sometimes waits for a keypress
I'm using "vivado -mode batch -source build.tcl" to build our bitstream and sometimes it is pausing to wait for a keypress, even though it never prompts me for such.   If I press enter it scrolls a lot of text at once and continues working.
Almost always when it stops it is right after here:
# wait_on_run impl_1
[Wed Oct 31 10:22:09 2018] Waiting for impl_1 to finish...
It is at this point that it does a whole LOT of processing, but sometimes it needs me to press enter before it goes on:
*** Running vivado
    with args -log top.vdi -applog -m64 -product Vivado -messageDb vivado.pb -mode batch -source top.tcl -notrace
Anyone know why it may be pausing here?  Its kind of annoying.  I'm using the Windows SDK kit version of "vivado".   I wonder if there is some kind of logic inside of vivado to pause if I have switched the active Window away from the one running vivado...   it would be odd, but possible I guess.  None of my other processing tools do that.
Re: command line vivado sometimes waits for a keypress
Hi @skidaddytn,
Ideally, Vivado should not pause. From your scenario, it seems that vivado is running but it is not printing the log and appears to be as if it has been paused. Please confirm if you are using the supported OS as mentioned at page 11 of UG973
Visitor skidaddytn
O/S is Windows 10 1803.   I have figured out something however...  it does not pause as long as you leave the window *active*.   If you click the focus away from the command prompt window, then its like it waits for you to re-focus on the window before spewing out all the output.Very strange behavior as no other utilities have such a pause mechanism built in...     I did not even know it was possible for a command line application to act in such a way.    Luckily for our automated builds, no one is using the machine so it always completes.
