designutils insert_buffer for skew fixing
Accepted Solution Solved
Accepted Solution
I'm not sure where the best place to post this is, but I've noticed the insert_buffer function in the xilinx designutils library is pretty useful for balancing skew in my clock tree.  I don't see any posts about the insert_buffer function though and I'm curious if it is safe to use for this.
I have an ASIC design that we really don't want to touch the source on, so HDL inserting anything is undesired.  We have a lot of clocks and auto-BUFG insertion really messes up the skew between clocks.  Using this function allows me to hand tune the clock paths a bit and get closer to meeting hold timing.  So far I've just been inserting a couple BUFGCEs, but I've now noticed I can also insert LUT1s.  I've had limited success with the tools automatically fixing the clock tree issues.
Are there problems with this idea that I'm not seeing?  Has anyone done this?
Re: designutils insert_buffer for skew fixing
@jefedenorsk there is nothing wrong with modifying the netlist after it has been implemented. In fact you add any kind of cell you want, not only buffers or LUT1 but any LUTx and make any other netlist changes you want. The issue is how you make sure that the netlist after you mess with it is still the netlist you undoubtedly verified in RTL. If you're running your verification and timing checks again after you make the changes you propose there is nothing wrong with the flow you suggest.
All Replies
