FPGADude99
export package pin from vivado project to create a new XDC file
Let's say I have a vivado project that I need to extract the XDC file from to use on another vivado project.  However, this vivado project has a complicated tcl script to setup the PIN_PACKAGE and IO_STD for the device.
Is there a way to export a new XDC file from this vivado project after elaborating the design, that represents how the TCL script has setup the IOs of the FPGA?
Basically, what I want is to export everything under:
   Open Elborated Design, Layout Menu->I/O planning, click Package Pins tab
and to put this list into a new XDC file automatically, then to take this XDC file and load it into a different vivado project for the same FPGA board.
hongh
Please try the below commands:
set f [open package_pin1.xdc a]
set my_ports [get_ports]
foreach port_i $my_ports {
puts $f "set_property PACKAGE_PIN [get_property PACKAGE_PIN $port_i] \[get_ports $port_i \] "
puts $f "set_property IOSTANDARD [get_property IOSTANDARD $port_i] \[get_ports $port_i \] "
close $f
