gauthier_auvray
flow tcl script
I use Vivado in batch mode with a tcl script that launch the different steps of the flow.
I am facing an issue with constraints files.
I would like to do the following:
1. Create project (toplevel, adding source files...) : OK
2. Add timing constraints file to constrs_1 : OK : add_files -fileset constrs_1 [glob $PrjDir/pr/def/$Target/timing_constraints.sdc ]
3. run synthesis: OK : launch_runs  synth_1; wait_on_run synth_1
4. Open synthesis run : OK : open_run synth_1
5. Then I source a tcl script that set IO constraints (pins, properties...)
6. Now I would like to create a toplevel.xdc which contains all IO constraints and add it to constrs_1. This is where I don't find solution. I also would like to keep my timing constraints file intact so that before launching implementation I have two files in constrs_1: timing_constraints.sdc and toplevel.xdc
7. Run implementation: OK : launch_runs impl_1 -to_step write_bitstream; wait_on_run impl_1
gauthier_auvray
Creating the directory is the solution.
Gauthier
surajc
Hi @gauthier_auvray
For 6 you can use the following tcl commands: ( assuming directory [pwd]/<proj_name>/<proj_name>.srcs/constrs_1/new is already created )
close [ open [pwd]/<proj_name>/<proj_name>.srcs/constrs_1/new/toplevel.xdc w ]
add_files -fileset constrs_1 [pwd]/<proj_name>/<proj_name>.srcs/constrs_1/new/toplevel.xdc
set_property used_in_synthesis false [get_files  [pwd]/<proj_name>/<proj_name>.srcs/constrs_1/new/toplevel.xdc]
set_property target_constrs_file [pwd]/<proj_name>/<proj_name>.srcs/constrs_1/new/toplevel.xdc [current_fileset -constrset]
But for this to work you need to add save_constraints -force command after te above commands so that the constraints set by the tcl in step 5 are saved in toplevel.xdc file
Also, the above path to the new file is not generic, I used [pwd] and <project_name> just for understanding
gauthier_auvray
Hi Surajc,
Thank you for your help.
At the end of synthesis, after opening synth_1 design, .srcs folder does not exists.
As a consequence,
fails:
open_run: Time (s): cpu = 00:00:34 ; elapsed = 00:00:45 . Memory (MB): peak = 1580.469 ; gain = 1249.559
Adding constraints...
couldn't open "D:/Gauthier/NUGGETH/fpga_carte_nuggeth/dev/pr/synth_pr_test/fpga_carte_nuggeth.srcs/constrs_1/new/fpga_carte_nuggeth.xdc": no such file or directory
while executing
"open $PR_ROOTDIR/$PROJECT_TOPLEVEL.srcs/constrs_1/new/$PROJECT_TOPLEVEL.xdc w "
Gauthier
surajc
Hi @gauthier_auvray
In that case, Try creating the directory in File Explorer and then executing the command.
Let me know what is its outcome
gauthier_auvray
Gauthier
