jreinauld
generate and compile SDK all in TCL
Hi all,
I am using Vivado and SDK 2019.1, and I have generated a simple Microblaze design.
Is it possible to export hardware, generate BSP, generate 'Hello world' project, compile it and get the ELF file, all in command line (using TCL presumably)?
- Julien
jreinauld
I found this!
https://www.xilinx.com/html_docs/xilinx2019_1/SDK_Doc/xsct/use_cases/xsct_howtoruntclscriptfiles.html
Great documentations, seems all I need to create BSPs and projects using SDK in command line \o/
jreinauld
Anyone?
I am 99% sure the buttons and menus of the SDK allowing to generate a BSP and an Hello world project correspond to TCL commands under the hood...
jreinauld
I found this!
