ronnywebers
Advisor
Advisor
how to detect wether an IP is already instantiated or not during the creation of a design using tcl?
I use different tcl (sub)scripts to create a project and bd.
For example I have a subscript that creates/instantiates the Zynq MPSoC IP on the bd, and then applies a saved configuration to it (preset)
I have 2 situations with my scripts:
* situation 1 : there is no / not yet a Zynq UltraScale+ MPSoC IP present in the bd, so the script needs to add the MPSoC IP to the bd (create cell ...), and then apply the preset / configuration
* situation 2 : at the point where my subscript kicks in, there is already a Zynq MPSoC IP present in the bd (and I cannot put 2 of them on the BD of course), so I should not add the IP (skipp the create cell ...), but just apply the MPSoC preset
Q1: how can I detect the presence of the MPSoC IP (or more general, of 'any' IP)?
So in pseudo code something like :
if (MPSoC IP) != present_in_bd:
   create_bd_cell -type ip -vlnv xilinx.com:ip:zynq_ultra_ps_e:3.2 zynq_ultra_ps_e_0
config_mpsoc_ip with preset.tcl
florentw
HI @ronnywebers
As mentioned by @amaccre , I guess one way to go is to use the get_ips command and check the length of the string array returned
Based on the other topic for the config of the ZynqMP:
source ./zynqMP_config.tcl
if {[llength [get_ips -quiet *zynq_ultra*]] != 1} {
	create_bd_cell -type ip -vlnv xilinx.com:ip:zynq_ultra_ps_e:3.3 zynq_ultra_ps_e_0
set_property -dict [concat [apply_preset [get_bd_cells zynq_ultra_ps_e_0]]] [get_bd_cells zynq_ultra_ps_e_0]
Florent
amaccre
Hi @ronnywebers ,
Are you looking for the get_ips tcl command that will list the IPs added to a project? If more particularly the IP added to a block design then the get_bd_cells tcl command will list the cells in a block design.
Best Regards
Aidan
Please mark the Answer as "Accept as solution" if this answered your question
Give Kudos to a post which you think is helpful and may help other users
florentw
HI @ronnywebers
Florent
ronnywebers
Advisor
Advisor
Thanks @florentw (and @amaccre ) that's what I'm looking for ... now wondering about 2 more details :
1) in my case the *zynq_ultra* was renamed by another script to 'mpsoc' ... would it be an option to scan for the vlnv 'xilinx.com:ip:zynq_ultra_ps_e'?
2) I should probably check the IP version before applying the preset ... or that's probably tackled if I check against the expected vivado version at the very beginning of my script ...?
florentw
Hi @ronnywebers
I would not really recommend you to do scripts too complicated checking every cases. If there is another script which is calling the IP mpsoc then this name should probably be passed to a following script. Because the more you add conditions, the more chances you can make it fail.
With that said, you can get the IPDEF property to get the IP name (and not the instance name). You will be able to do the same for the version if this is needed:
set zynqMP_IP ""
set my_ips [get_ips *]
foreach my_ip $my_ips {
      set ip_def [lindex [split [get_property IPDEF $my_ip] ":"] 2]
      if { $ip_def eq "zynq_ultra_ps_e" } {
         set zynqMP_IP $my_ip
if { ${zynqMP_IP} eq "" } {
	set zynqMP_IP [create_bd_cell -type ip -vlnv xilinx.com:ip:zynq_ultra_ps_e:3.3 zynq_ultra_ps_e_0]
set_property -dict [concat [apply_preset $zynqMP_IP]] $zynqMP_IP
Florent
ronnywebers
Advisor
Advisor
guess you're right about passing the name from the calling script ... but I learned a lot from the above, useful stuff, so thanks a lot!
florentw
HI @ronnywebers
That was fun for me to look at as well. But I guess I need to go back to my main activity now haha
Florent
