how to set global ram_style attribute in tcl command
i want to set ram_style to block in tcl command for all hirarchical modules in present project globally
Re: how to set global ram_style attribute in tcl command
HI @suraj.kole_imgtec,
Check out User Guide 912 Vivado Design Suite Properties Reference Guide
The Syntax is as follows.
set_property ram_style block [get_cells myram]
Values
• block: Instructs the tool to infer Block RAM type components.
• distributed: Instructs the tool to infer distributed LUT RAMs.
• registers: Instructs the tool to infer registers instead of RAMs.
• ultra: Instructs the tool to use the UltraScale+ URAM primitives.
So in your case it would be something similar to this when applied pre synthesis.
set_property ram_style block [get_cells -hierarchical -filter { PRIMITIVE_TYPE =~ RTL_MEMORY.*.* } ]
You can use the Find command in the GUI to verify that you are applying the constraint to to correct primitives.
After you run synthesis, use report_utilization to verify that the RAM is using block ram as opposed to distributed.
Best Regards
Aidan
Please mark the Answer as "Accept as solution" if this answered your question
Give Kudos to a post which you think is helpful and may help other users
Newbie suraj.kole
   I have some doubts...
1. set_property ram_style block [get_cells -hierarchical -filter { PRIMITIVE_TYPE =~ RTL_MEMORY.*.* } ]
     in this is it RTL_MEMORY or BLOCKRAM
2. how does above command if applied in pre-synthesys will give valid get_cells resuls or return non-null list
