how to test if bd exist
how can I test whether a design contains a block design or not?
llength [get_bd_designs]
returns the number of block designs that has been opened in the project.
I need to open the first block design in the list, if there is any. How can I do this?
@jack.roundhouse
Check if "get_files *.bd" helps.
--Syed
@jack.roundhouse
--Syed
