s002hwj
passing variable/parameter
is there way to passing variable parameter between linked .tcl  for example
in my top.tcl
set a 5
 source sub.tcl
put $a
in sub.tcl
  set a 7
result output will be 7 in the top.tcl
avrumw
Guide
Guide
This is the normal behavior of Tcl.
A "source" command simply executes the Tcl commands located in the file. These commands are executed in the same context (same namespace) as where it was called from. In other words, the commands in a file that is "sourced" are not a subprogram.
This is not like calling a procedure. A procedure is defined with a "proc" command and executed by invoking the named procedure (with arguments). The procedure is executed in a different namespace; any variable used in a procedure is in a different namespace than the calling scope.
Avrum
