yakir_mishli
schematic view with tcl
1. Can I use TCL commands to create custom schematic view? like my data path in design?
2. Can I use TCL commands to color highlighting nets, cells...?
Yakir.
hongh
1. You can use the command to create cell, net and connect them, then open schematic for these objects.(F4)
   create_cell, create_net, connect_net ...
2. This example highlights the specified cells in green:
   highlight_objects -color green -leaf_cells [get_cells cpuEngine/*]
hongh
