younggeun
set false path critical warning
I want to use the set false path tcl in xdc as below.
set_false_path -from [get_clocks -of_objects [get_pins rftest_base_blk/pll_adc_jesd_blk/inst/mmcme4_adv_inst/CLKOUT0]] -to [get_clocks -of_objects [get_pins rftest_base_blk/bd_rftest_main_1_wrapper_blk/bd_rftest_main_1_i/clk_wiz_0/inst/mmcme4_adv_inst/CLKOUT3]]
but critical warning appears.
I exported the path of get_pins from synthesized design. by using show_objects -name find_2 [get_cells -hierarchical -filter { PRIMITIVE_TYPE =~ CLOCK.PLL.* } ].
the pin is output from mmcm ip.
how can i find exact pin name for using async or set_false_path timing tcl without critical warning??
hongh
In the critical warning, "No object" means clock is not found, instead of pin not being found.
When you intend to refer to a clock in a constraint (tcl command), the clock should be created ahead of time.
Please confirm that the set_false_path command is executed after create_clock command. Command "report_compile_order" can help you to find XDC file compiling order.
hongh
