Advisor ronnywebers
Advisor
timing constraint - get clock period using tcl instead of hard-coding it
For a CDC in my design, I have a set_max_delay -datapath_only constraint
the value of 62.5ns corresponds to 1 clock period of the destination clock (16MHz). This clock is an output of an MMCM in my (zynq) design. The MMCM is configured using a 'clock generator wizard'
Now what bothers me is that the 62.5ns is a hardcoded value, what if I later decide to change the clock frequency in the 'clock generator wizard' and forget to update this value?
Q: can I get this clock period using a tcl command instead of hard-coding this value?
# constrain the datapath between the src data register and dst data register
set_max_delay -from [get_cells design_1_i/snap_sin_rx_0/U0/sync_2ff_i/src_din_reg_reg[*]] -to [get_cells design_1_i/snap_sin_rx_0/U0/sync_2ff_i/data_dst_clk_reg[*]] -datapath_only 62.5
Re: timing constraint - get clock period using tcl instead of hard-coding it
Hi @ronnywebers,
I have tried this in small test case and I am able to get the value using TCL command.
Below are the commands I have used.
get_property PERIOD [get_clocks <clock_name>]
If you don't know exact clock name then use below command.
get_property PERIOD [get_clocks -of_objects [get_pins <pin name>]]
It will give you the period value in Nanoseconds which you can use in your constraints.
Yash
Hi @ronnywebers,
Yash
Advisor ronnywebers
Advisor
thanks @yashp, that seems to work, I tried this:
get_property PERIOD [get_clocks -of_objects [get_cells design_1_i/snap_sin_rx_0/U0/sync_2ff_i/data_dst_clk_reg[0]]]
that returns :
76.92184448242187500
which corresponds to my 13MHz clock.
would you round this value or doesn't it matter for the timing analyser?
I guess I missed your reply.
Good that you are able get the value using TCL command.
In any constraints you can give value as xx.yyy ns but I am not sure if you are getting value as 76.92184448242187500.
Did you tried without any changes? Is there any issue?
Yash
Guide avrumw
Guide
I wouldn't worry about the precision. The tool always has to deal with rounding issues (since we often work with irrational clock periods). Specifying the full precision will be OK - the tools will round as they need to.
Avrum
