ViennaAudio
trim and stretch function implementation
Hi.
I have to implement the function explained in attached picture, please help!!!
Kind regards
dgisselq
@ViennaAudio,
Why create new arrays?  Why not just step though this array twice as fast, or three times as fast, etc, when reading from it?
I must still be missing something here.
Dan
dgisselq
@ViennaAudio,
I'm not sure I understand the problem statement from just this information well enough to comment upon it here.
Dan
watari
Hi @ViennaAudio
Using PLL as a sampling clock and FIFO or some memory controller to trim signal seem best solution.
Would you consider them ?
BTW, how to implement them ? By tcl ?
If so, it is not able to implement it by tcl.
ViennaAudio
hope i can explain it clearly
given an array of 1024 16bits values, (it could be whatever waveform or even noise)
fill a new array of 1024 16bits values containing 2 cycles of original array,
fill a new array of 1024 16bits values containing 3 cycles of original array
fill a new array of 1024 16bits values containing 4 cycles of original array,
up to 10 cycles, so 10 arrays
thx for your attention
ViennaAudio
thx a lot for your attention,
i surely posted this in a wrong board... so ye, no tlc to implement this.
Could you explain me better your idea pls?
Best regards
dgisselq
@ViennaAudio,
Dan
watari
Hi @ViennaAudio
If you use FPGA, I suggest you to use Vivado to build FPGA design.
Also, you can find MMCM as PLL and some FIFO and memory controller in it.
ViennaAudio
Thx Dan
I know, that is a really good point, and i would do that if this operation was the last one of the design.
there are two more operations to do after this one
This block is an harmonic generator for unknown incoming waveform
i'm quite scared of implementing 9 wt oscillators, could that lead to sync problems?
