vivado 2017.4 installer for windows
I've been trying to install vivado on a new laptop for school but once I've chose all the options and put in my log in info there seems to be a login validation error. I hit login and nothing happens. Every once in a while i get a box that says please wait but it just goes back to asking for my credentionals Are the download servers down?
Re: vivado 2017.4 installer for windows
Are you using Webinstall?
Could be due to a slow network.
You can try to download the whole install package and then install it locally.
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
I was using the web installer. Though now when i go to download the whole install package I can not even log in to my account on the website
When I click log in the page just reloads. My information is correct too because if I change the credentials I get an invalid credential error.
What could cause this?
Please refer to the below AR:
https://www.xilinx.com/support/answers/60138.html
