amir.massah
write_project_tcl - wrong filesets
Hi to all,
I am trying to manage my Vivado projects with write_project_tcl in Vivado 2016.4.
I am getting errors when I am running the TCL generated by write_project_tcl. In my projects, I have a lot of my own IPs in which I have used block memories and I have problems with the instantiated Xilinx IP inside my IPs. I looked inside the TCL, I can see that it looks for a filesets named as the IP which I have customized and instantiated inside my own IPs. This is an example:
# Set IP repository paths
set obj [get_filesets SHCRef_Mem144x144x1536]
set_property "ip_repo_paths" "[file normalize "$origin_dir/../KA91_FPGA/KA91_TCLTest/cores"]" $obj
I guess I should change something in my project before generating the TCL by write_project_tcl.
Thank you very much.
Amir
rshekhaw
Hi @amir.massah ,
Try using write_bd_tcl instead of write_project_tcl. Please check page no.1536 of below link:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_4/ug835-vivado-tcl-commands.pdf
Raj
amir.massah
Hi @rshekhaw,
Thank you for your reply.
But I have also other IPs in addition to the block design in my project that I want to manage them. The write_bd_tcl does not create a project and add files and so on.
asbuscemi
I am also having an issue with the ip_repo_paths.  I'm using Vivado 2019.1 and when I use the write_project_tcl, the resulting tcl file does not point to the correct place relative to the origin directory.  It's always one folder too high in the hierarchy.  Whenever I generate the script I have to go to that line in the tcl script and add a "../" after the origin directory.  Seems like a bug that should be fixed.
