取消
显示结果
显示  仅  | 搜索替代
您的意思是:
807 次查看
注册日期: ‎07-23-2019
使用Xilinx_Vivado_SDK_2018.2_0614_1954编译Freedom的E300 Arty报错,请帮忙看一下,谢谢!
跳至解决方案
make -f Makefile.e300artydevkit mcs
make -C /share/freedom/bootrom/xip romgen
echo /share/freedom/rocket-chip/src/main/resources/vsrc/AsyncResetReg.v /share/freedom/rocket-chip/src/main/resources/vsrc/plusarg_reader.v /share/freedom/sifive-blocks/vsrc/SRLatch.v /share/freedom/fpga-shells/xilinx/common/vsrc/PowerOnResetFPGAOnly.v /share/freedom/builds/e300artydevkit/sifive.freedom.everywhere.e300artydevkit.E300ArtyDevKitConfig.rom.v /share/freedom/builds/e300artydevkit/sifive.freedom.everywhere.e300artydevkit.E300ArtyDevKitConfig.v > /share/freedom/builds/e300artydevkit/sifive.freedom.everywhere.e300artydevkit.E300ArtyDevKitConfig.vsrcs.F
make[1]: Entering directory '/share/freedom/bootrom/xip'
dtc -I dts -O dtb -o /share/freedom/builds/e300artydevkit/sifive.freedom.everywhere.e300artydevkit.E300ArtyDevKitConfig.dtb /share/freedom/builds/e300artydevkit/sifive.freedom.everywhere.e300artydevkit.E300ArtyDevKitConfig.dts
/usr/local/riscv/toolchain/bin/riscv64-unknown-elf-gcc -march=rv32imac -mabi=ilp32 -O2 -std=gnu11 -Wall -I. -nostartfiles -fno-common -g -DXIP_TARGET_ADDR=0x20400000 -DDEVICE_TREE='"/share/freedom/builds/e300artydevkit/sifive.freedom.everywhere.e300artydevkit.E300ArtyDevKitConfig.dtb"' -static -nostdlib -o /share/freedom/builds/e300artydevkit/xip.elf xip.S
/usr/local/riscv/toolchain/bin/riscv64-unknown-elf-objcopy -O binary /share/freedom/builds/e300artydevkit/xip.elf /share/freedom/builds/e300artydevkit/xip.bin
od -t x4 -An -w4 -v /share/freedom/builds/e300artydevkit/xip.bin > /share/freedom/builds/e300artydevkit/xip.hex
/share/freedom/rocket-chip/scripts/vlsi_rom_gen /share/freedom/builds/e300artydevkit/sifive.freedom.everywhere.e300artydevkit.E300ArtyDevKitConfig.rom.conf /share/freedom/builds/e300artydevkit/xip.hex > /share/freedom/builds/e300artydevkit/rom.v
make[1]: Leaving directory '/share/freedom/bootrom/xip'
mv /share/freedom/builds/e300artydevkit/rom.v /share/freedom/builds/e300artydevkit/sifive.freedom.everywhere.e300artydevkit.E300ArtyDevKitConfig.rom.v
cd /share/freedom/builds/e300artydevkit; vivado \
-nojournal -mode batch \
-source /share/freedom/fpga-shells/xilinx/common/tcl/vivado.tcl \
-tclargs \
-top-module "E300ArtyDevKitFPGAChip" \
-F "/share/freedom/builds/e300artydevkit/sifive.freedom.everywhere.e300artydevkit.E300ArtyDevKitConfig.vsrcs.F" \
-ip-vivado-tcls "" \
-board "arty"
****** Vivado v2018.2 (64-bit)
**** SW Build 2258646 on Thu Jun 14 20:02:38 MDT 2018
**** IP Build 2256618 on Thu Jun 14 22:10:49 MDT 2018
** Copyright 1986-2018 Xilinx, Inc. All Rights Reserved.
# set scriptdir [file dirname [info script]]
# source [file join $scriptdir "prologue.tcl"]
## set ip_vivado_tcls {}
## while {[llength $argv]} {
## set argv [lassign $argv[set argv {}] flag]
## switch -glob $flag {
## -top-module {
## set argv [lassign $argv[set argv {}] top]
## -F {
## # This should be a simple file format with one filepath per line
## set argv [lassign $argv[set argv {}] vsrc_manifest]
## -board {
## set argv [lassign $argv[set argv {}] board]
## -ip-vivado-tcls {
## set argv [lassign $argv[set argv {}] ip_vivado_tcls]
## -pre-impl-debug-tcl {
## set argv [lassign $argv[set argv {}] pre_impl_debug_tcl]
## -post-impl-debug-tcl {
## set argv [lassign $argv[set argv {}] post_impl_debug_tcl]
## default {
## return -code error [list {unknown option} $flag]
## if {![info exists top]} {
## return -code error [list {--top-module option is required}]
## if {![info exists vsrc_manifest]} {
## return -code error [list {-F option is required}]
## if {![info exists board]} {
## return -code error [list {--board option is required}]
## set commondir [file dirname $scriptdir]
## set boarddir [file join [file dirname $commondir] $board]
## source [file join $boarddir tcl board.tcl]
### set name {arty}
### set part_fpga {xc7a35ticsg324-1L}
### set part_board {digilentinc.com:arty:part0:1.1}
### set bootrom_inst {rom}
## set constraintsdir [file join $boarddir constraints]
## set srcdir [file join $commondir vsrc]
## set wrkdir [file join [pwd] obj]
## set ipdir [file join $wrkdir ip]
## create_project -part $part_fpga -force $top
WARNING: [Device 21-436] No parts matched 'xc7a35ticsg324-1L'
ERROR: [Coretcl 2-106] Specified part could not be found.
while executing
"source [file join $scriptdir "prologue.tcl"]"
(file "/share/freedom/fpga-shells/xilinx/common/tcl/vivado.tcl" line 7)
INFO: [Common 17-206] Exiting Vivado at Tue Jul 23 15:39:10 2019...
common.mk:81: recipe for target '/share/freedom/builds/e300artydevkit/obj/E300ArtyDevKitFPGAChip.bit' failed
make: *** [/share/freedom/builds/e300artydevkit/obj/E300ArtyDevKitFPGAChip.bit] Error 1
0 项奖励
1 解答
已接受的解答
767 次查看
注册日期: ‎02-28-2019
只要是支持的系统,问题不大。
在Add Design Tools or Devices 中安装7系列器件。
在原帖中查看解决方案
0 项奖励
6 回复数
804 次查看
注册日期: ‎02-28-2019
Hi @zhuxuanlong ,
log显示找不到您指定的器件,您可以检查一下是否安装了相关器件---xc7a35ticsg324-1L。
0 项奖励
792 次查看
注册日期: ‎07-23-2019
我安装了还是不行,看了一下boardfile里面都有这个单板
cp -rv ./vivado-boards/new/board_files/* /opt/Xilinx/Vivado/2018.2/data/boards/board_files/
我搜索了一下vivado里面的board_files
/opt/Xilinx/Vivado/2018.2/data/boards/board_files/arty/C.0# cat board.xml | grep "xc7a35ticsg324-1L"
<component name="part0" display_name="Arty" type="fpga" part_name="xc7a35ticsg324-1L" pin_map_file="part0_pins.xml" vendor="xilinx"
0 项奖励
787 次查看
注册日期: ‎02-28-2019
在vivado新建工程中能找到这个器件或这个board吗?
0 项奖励
770 次查看
注册日期: ‎07-23-2019
看不到。也就是vivado看不到board_files下面的单板,我重启了系统还是一样。我的ubuntu系统是中文的,这块跟中文有关系么?
0 项奖励
768 次查看
注册日期: ‎02-28-2019
只要是支持的系统,问题不大。
在原帖中查看解决方案
0 项奖励
750 次查看
注册日期: ‎07-23-2019
嗯,安装后重启vivado可以了。谢谢!
0 项奖励
