取消
显示结果
搜索替代
您的意思是:
Visitor xjb
355 次查看
注册日期: ‎10-31-2018
Common 17-69] Command failed: This design contains one or more cells for which bitstream generation is not permitted
转到解答
编译工程时报如下错误:
[Common 17-69] Command failed: This design contains one or more cells for which bitstream generation is not permitted: system_i/cpri_wrapper_0/inst/i_cpri_wrapper/cpri_block/cpri_i/U0/cpri_i/cpri_i (cpri_gen) If a new IP Core license was added, in order for the new license to be picked up, the current netlist needs to be updated by resetting and re-generating the IP output products before bitstream generation.
license状态如下:
请问导致这种情况的原因是什么,该如何处理?
0 项奖励
1 个已接受解答
已接受的解答
324 次查看
注册日期: ‎11-05-2010
回复: Common 17-69] Command failed: This design contains one or more cells for which bitstream generation is not permitted
转到解答
Hi, @xjb ,
请参考AR-58758:
https://www.xilinx.com/support/answers/58758.html
CPRI IP的License Host ID 和本机并不相符.
0 项奖励
2 条回复2
325 次查看
注册日期: ‎11-05-2010
转到解答
Hi, @xjb ,
请参考AR-58758:
0 项奖励
Visitor xjb
245 次查看
注册日期: ‎10-31-2018
转到解答
谢谢你,现在问题已经解决了。
0 项奖励
