取消
显示结果
搜索替代
您的意思是:
Newbie lewis@10086
758 次查看
注册日期: ‎01-28-2019
Vivado仿真时报错
转到解答
Vivado Simulator 2018.3
Copyright 1986-1999, 2001-2018 Xilinx, Inc. All Rights Reserved.
Running: D:/Xilinx/Vivado/2018.3/bin/unwrapped/win64.o/xelab.exe -wto de96dcb0a88b47b09f18a16821f53457 --incr --debug typical --relax --mt 2 -L xil_defaultlib -L unisims_ver -L unimacro_ver -L secureip --snapshot sim_at7_behav xil_defaultlib.sim_at7 xil_defaultlib.glbl -log elaborate.log
Using 2 slave threads.
WARNING: [XSIM 43-3431] One or more environment variables have been detected which affect the operation of the C compiler. These are typically not set in standard installations and are not tested by Xilinx, however they may be appropriate for your system, so the flow will attempt to continue. If errors occur, try running xelab with the "-mt off -v 1" switches to see more information from the C compiler. The following environment variables have been detected:
Starting static elaboration
Completed static elaboration
Starting simulation data flow analysis
Completed simulation data flow analysis
Time Resolution for simulation is 1ps
Compiling module xil_defaultlib.at7
Compiling module xil_defaultlib.sim_at7
Compiling module xil_defaultlib.glbl
ERROR: [XSIM 43-3409] Failed to compile generated C file xsim.dir/sim_at7_behav/obj/xsim_1.c.
ERROR: [XSIM 43-3915] Encountered a fatal error. Cannot continue. Exiting...
操作系统为:Win10
Vivado版本为2018.3
0 项奖励
1 个已接受解答
已接受的解答
Newbie lewis@10086
703 次查看
注册日期: ‎01-28-2019
回复: Vivado仿真时报错
转到解答
谢谢,重装系统解决了。
0 项奖励
2 条回复2
705 次查看
注册日期: ‎11-05-2010
回复: Vivado仿真时报错
转到解答
Hi, lewis@10086 ,
方便提供你的仿真文件或者工程以便复现这个问题吗?
0 项奖励
Newbie lewis@10086
704 次查看
注册日期: ‎01-28-2019
回复: Vivado仿真时报错
转到解答
谢谢,重装系统解决了。
0 项奖励
