取消
显示结果
搜索替代
您的意思是:
Newbie efsavg
2,065 次查看
注册日期: ‎07-11-2018
Vivado 2018打开项目闪退的现象
以前用的好好的,前两天回家的时候,电脑硬盘移动了,后来vivado就崩溃了,具体状况:
1.闪退
2.正常的***.v文件显示是non_module files
3,出现了如下的报错:
第一个报错文件:
# Vivado v2018.2 (64-bit)
# SW Build 2258646 on Thu Jun 14 20:03:12 MDT 2018
# IP Build 2256618 on Thu Jun 14 22:10:49 MDT 2018
# Start of session at: Wed Jul 11 20:27:33 2018
# Process ID: 4940
# Current directory: C:/Users/Think/Desktop
# Command line: vivado.exe -gui_launcher_event rodinguilauncherevent14272
# Log file: C:/Users/Think/Desktop/vivado.log
# Journal file: C:/Users/Think/Desktop\vivado.jou
start_gui
create_project project_1 C:/Users/Think/project_1 -part xc7vx485tffg1157-1
INFO: [IP_Flow 19-234] Refreshing IP repositories
INFO: [IP_Flow 19-1704] No user IP repositories specified
INFO: [IP_Flow 19-2313] Loaded Vivado IP repository 'E:/Xilinx/Vivado/2018.2/data/ip'.
create_project: Time (s): cpu = 00:00:24 ; elapsed = 00:00:21 . Memory (MB): peak = 864.613 ; gain = 57.195
file mkdir C:/Users/Think/project_1/project_1.srcs/sources_1/new
close [ open C:/Users/Think/project_1/project_1.srcs/sources_1/new/lab.v w ]
add_files C:/Users/Think/project_1/project_1.srcs/sources_1/new/lab.v
第二个报错文件:
# An unexpected error has occurred (EXCEPTION_ACCESS_VIOLATION)
Stack:
no stack trace available, please use hs_err_<pid>.dmp instead.
0 项奖励
4 条回复4
Newbie efsavg
2,063 次查看
注册日期: ‎07-11-2018
回复: Vivado 2018打开项目闪退的现象
请社区的xilinx大神解救呀
0 项奖励
2,020 次查看
注册日期: ‎05-15-2008
试过卸载重新安装vivado吗?
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
0 项奖励
2,017 次查看
注册日期: ‎11-05-2010
先参考一下 AR59304:
https://www.xilinx.com/support/answers/59304.html
0 项奖励
Newbie efsavg
2,010 次查看
注册日期: ‎07-11-2018
您好,试过了,原本装的是18.2后来重复了三四次,都不行,换了17.4也不行
0 项奖励
