取消
显示结果
显示  仅  | 搜索替代
您的意思是:
Adah
342 次查看
注册日期: ‎04-02-2021
creat hdl wrapper
creat hdl wrapper时遇到下列错误,希望能得到大家的帮助
[BD 41-758] The following clock pins are not connected to a valid clock source:
/processing_system7_0/M_AXI_GP0_ACLK
[BD 41-1031] Hdl Generation failed for the IP Integrator design D:/PYNQ/OFDM/vivadofft/project_2/project_2.srcs/sources_1/bd/design_1/design_1.bd
0 项奖励
6 回复数
Hrishikesh
339 次查看
注册日期: ‎09-26-2020
You need to connect the FCLK_CLK0 to all the clk ports, you also should complete the design before you go for creation of HDL Wrapper.
1. Complete all connections
2. Validate design to make sure there are no problems
3. Generate Output products
4. Create HDL Wrapper
Try Following this sequence.
0 项奖励
Adah
322 次查看
注册日期: ‎04-02-2021
你好,连了clk之后,出现了critical warning,如下
[BD 41-759] The input pins (listed below) are either not connected or do not have a source port, and they don't have a tie-off specified. These pins are tied-off to all 0's to avoid error in Implementation flow.
Please check your design and connect them as needed:
/fft_top_0/direction_ap_vld
/fft_top_0/ap_start
0 项奖励
Love24
319 次查看
注册日期: ‎10-22-2020
看你的电路图,M_AXI_GP0这组AXI总线没有用到,可以直接不勾选它,这样的话就不会有GP0_ACLK这个端口了,这个端口提供的时钟就是给AXI总线用的。
0 项奖励
Adah
310 次查看
注册日期: ‎04-02-2021
请问在哪取消勾选呢
0 项奖励
Love24
307 次查看
注册日期: ‎10-22-2020
双击ZYNQ框,进入配置界面,PS-PL configuration→AXI Non Secure Enablement→GP master AXI interface,取消勾选GP0即可
0 项奖励
Adah
286 次查看
注册日期: ‎04-02-2021
这个问题已经解决,谢谢
0 项奖励
