取消
显示结果
显示  仅  | 搜索替代
您的意思是:
yangboyang
465 次查看
注册日期: ‎06-13-2020
vivado 时钟管理模块生成问题
生成不了clocking wizard ip核点击生成会报错 INFO: [IP_Flow 19-1686] Generating 'Synthesis' target for IP 'clk_wiz_1'... can't read "sel_PRIMITIVE": no such variable CRITICAL WARNING: [IP_Flow 19-1747] Failed to deliver file 'd:/Xilinx/Vivado/2018.3/data/ip/xilinx/clk_wiz_v6_0/ttcl/xdc.ttcl': can't read "sel_PRIMITIVE": no such variable can't read "clkin1_buf": no such variable CRITICAL WARNING: [IP_Flow 19-1747] Failed to deliver file 'd:/Xilinx/Vivado/2018.3/data/ip/xilinx/clk_wiz_v6_0/ttcl/late_xdc.ttcl': can't read "clkin1_buf": no such variable can't read "clkin1_buf": no such variable CRITICAL WARNING: [IP_Flow 19-1747] Failed to deliver file 'd:/Xilinx/Vivado/2018.3/data/ip/xilinx/clk_wiz_v6_0/ttcl/OOC_xdc.ttcl': can't read "clkin1_buf": no such variable can't read "notes": no such variable ERROR: [Ipptcl 7-5] XIT evaluation error: can't read "notes": no such variable ERROR: [Common 17-39] 'xit::source_ipfile' failed due to earlier errors. CRITICAL WARNING: [IP_Flow 19-1747] Failed to deliver file 'd:/Xilinx/Vivado/2018.3/data/ip/xilinx/clk_wiz_v6_0/ttcl/core_v.ttcl': ERROR: [Common 17-39] 'xit::source_ipfile' failed due to earlier errors. ERROR: [IP_Flow 19-167] Failed to deliver one or more file(s). ERROR: [IP_Flow 19-3505] IP Generation error: Failed to generate IP 'clk_wiz_1'. Failed to generate 'Synthesis' outputs: ERROR: [IP_Flow 19-98] Generation of the IP CORE failed. Failed to generate IP 'clk_wiz_1'. Failed to generate 'Synthesis' outputs:
0 项奖励
4 回复数
yangc
453 次查看
注册日期: ‎02-28-2019
使用global mode的方式生成ip还会报错吗?具体是怎么添加IP的?
0 项奖励
yangboyang
390 次查看
注册日期: ‎06-13-2020
用global也会报错,生成ip流程就是全部使用默认设置也会报错
0 项奖励
yangc
383 次查看
注册日期: ‎02-28-2019
是单独的clock wizard这个IP出错还是全部IP都会有这个问题?
0 项奖励
yangboyang
337 次查看
注册日期: ‎06-13-2020
只有clocking wizard这个ip有问题,我换了2019.1就没问题了。
0 项奖励
