取消
显示结果
搜索替代
您的意思是:
Observer yanjian
578 次查看
注册日期: ‎11-28-2018
vivado hls 图像处理函数使用问题
hls::InitUndistortRectifyMap ()
hls::Remap().
这两个函数如何使用?  能否给实例!!!!谢谢!我按照UG902里面的参考,写得不对。
头文件:
typedef hls::Mat<MAX_HEIGHT, MAX_WIDTH,HLS_16SC2> MAP ;
typedef hls::Mat<3,3,HLS_32F> EYE_MAP ;
typedef hls::Mat<3, 3,HLS_32FC1> Matrix_type ;
typedef hls::Mat<1, 5,HLS_32FC1> Coeff_type ;
函数文件
MAP mapx;
MAP mapy;
EYE_MAP R ={1,0,0,0,1,0,0,0,1} ;
Matrix_type cameraMatrix = {2892.45384, -0.77943, 925.03464,0, 2896.55407, 587.20266,0, 0, 1};
Coeff_type distCoeffs ={ 0.12394, -10.03379, -0.00295, 0.00988, 174.17315};
gray_IMAGE dst(rows,cols);
hls::AXIvideo2Mat(src, src0);
hls::InitUndistortRectifyMapInverse(cameraMatrix,distCoeffs,R,mapx,mapy);
hls::Remap(src0,src00,mapx,mapy);
编译错误信息:
../../../../thin.cpp: In function 'void thinning(AXI_STREAM&, ap_int<11>, ap_int<11>, Point3f*)':
../../../../thin.cpp:102:34: error: in C++98 'R' must be initialized by constructor, not by '{...}'
../../../../thin.cpp:102:34: error: could not convert '{1, 0, 0, 0, 1, 0, 0, 0, 1}' from '<brace-enclosed initializer list>' to 'EYE_MAP {aka hls::Mat<3, 3, 5>}'
../../../../thin.cpp:103:96: error: in C++98 'cameraMatrix' must be initialized by constructor, not by '{...}'
../../../../thin.cpp:103:96: error: could not convert '{2.892453840000000127474777400493621826171875e+3, -7.79429999999999956195040340389823541045188903809e-1, 9.250346399999999675856088288128376007080078125e+2, 0, 2.896554070000000137952156364917755126953125e+3, 5.872026600000000371437636204063892364501953125e+2, 0, 0, 1}' from '<brace-enclosed initializer list>' to 'Matrix_type {aka hls::Mat<3, 3, 5>}'
../../../../thin.cpp:104:78: error: in C++98 'distCoeffs' must be initialized by constructor, not by '{...}'
../../../../thin.cpp:104:78: error: could not convert '{1.23939999999999994617638776617241092026233673096e-1, -1.00337899999999997646682459162548184394836425781e+1, -2.94999999999999993130495035131843906128779053688e-3, 9.87999999999999989341858963598497211933135986328e-3, 1.74173149999999992587618180550634860992431640625e+2}' from '<brace-enclosed initializer list>' to 'Coeff_type {aka hls::Mat<1, 5, 5>}'
../../../../thin.cpp:110:74: error: no matching function for call to 'InitUndistortRectifyMapInverse(Matrix_type&, Coeff_type&, EYE_MAP&, MAP&, MAP&)'
../../../../thin.cpp:110:74: note: candidate is:
C:/Xilinx/Vivado_HLS/2016.3/include/hls/hls_video_undistort.h:646:6: note: template<class CMT, class DT, class ICMT, int ROWS, int COLS, int MAP1_T, int MAP2_T, int N> void hls::InitUndistortRectifyMapInverse(hls::Window<3, 3, CMT>, DT (&)[N], hls::Window<3, 3, ICMT>, hls::Mat<ROWS, COLS, MAP1_T>&, hls::Mat<ROWS, COLS, MAP2_T>&, int)
../../../../thin.cpp:111:34: error: no matching function for call to 'Remap(gray_IMAGE&, gray_IMAGE&, MAP&, MAP&)'
../../../../thin.cpp:111:34: note: candidate is:
C:/Xilinx/Vivado_HLS/2016.3/include/hls/hls_video_undistort.h:383:6: note: template<int WIN_ROW, int ROWS, int COLS, int SRC_T, int DST_T, int MAP1_T, int MAP2_T> void hls::Remap(hls::Mat<ROWS, COLS, SRC_T>&, hls::Mat<ROWS, COLS, DST_T>&, hls::Mat<ROWS, COLS, MAP1_T>&, hls::Mat<ROWS, COLS, MAP2_T>&, int)
make: *** [obj/thin.o] Error 1
ERROR: [SIM 211-100] 'csim_design' failed: compilation error(s).
0 项奖励
1 条回复1
529 次查看
注册日期: ‎05-23-2018
回复: vivado hls 图像处理函数使用问题
Hi, @yanjian
建议参考一下xapp1167所带附件中的remap例程,其中有这两个函数的调用方法。附件链接如下所示。
https://www.xilinx.com/member/forms/download/design-license.html?cid=323570&filename=xapp1167.zip
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
0 项奖励
