取消
显示结果
搜索替代
您的意思是:
Visitor yanjian
205 次查看
注册日期: ‎11-28-2018
vivado hls 编译错误
#include "thinn.h"
#include "hls_opencv.h"
//#include<iostream>
using namespace std;
int main(int argc,char**argv)
IplImage* src=cvLoadImage(INPUT_IMAGE,0);
IplImage* dst = cvCreateImage(cvGetSize(src), src->depth, src->nChannels);
//cvShowImage("hls_src", src);
//HLS视频库处理
AXI_STREAM src_axi;
Point3f array_out[MAX_WIDTH];
IplImage2AXIvideo(src, src_axi);
thinning(src_axi, src->height, src->width,array_out);
// cout<<"array_out:"<<array_out<<endl;
cvReleaseImage(&src);
cvWaitKey(0);
 return 0;
编译信息
Starting C simulation ...
C:/Xilinx/Vivado_HLS/2016.3/bin/vivado_hls.bat D:/xiilx/milianke/array_test/array_test/solution1/csim.tcl
INFO: [HLS 200-10] Running 'C:/Xilinx/Vivado_HLS/2016.3/bin/unwrapped/win64.o/vivado_hls.exe'
INFO: [HLS 200-10] For user 'Administrator' on host 'win-20170406dtz' (Windows NT_amd64 version 6.1) on Tue Dec 04 16:44:54 +0800 2018
INFO: [HLS 200-10] In directory 'D:/xiilx/milianke/array_test'
INFO: [HLS 200-10] Opening project 'D:/xiilx/milianke/array_test/array_test'.
INFO: [HLS 200-10] Opening solution 'D:/xiilx/milianke/array_test/array_test/solution1'.
INFO: [SYN 201-201] Setting up clock 'default' with a period of 10ns.
INFO: [HLS 200-10] Setting target device to 'xc7z014sclg400-1'
INFO: [SIM 211-2] *************** CSIM start ***************
WARNING: [SIM 211-51] HLS only supports CLANG compiler in Linux.
INFO: [SIM 211-4] CSIM will launch GCC as the compiler.
Compiling ../../../../testbench.cpp in debug mode
Compiling ../../../../thin.cpp in debug mode
Generating csim.exe
In file included from C:/Xilinx/Vivado_HLS/2016.3/include/floating_point_v7_0_bitacc_cmodel.h:143:0,
from C:/Xilinx/Vivado_HLS/2016.3/include/hls_half.h:40,
from C:/Xilinx/Vivado_HLS/2016.3/include/hls/utils/x_hls_utils.h:37,
from C:/Xilinx/Vivado_HLS/2016.3/include/hls/hls_axi_io.h:40,
from C:/Xilinx/Vivado_HLS/2016.3/include/hls_video.h:48,
from ../../../../thinn.h:3,
from ../../../../testbench.cpp:1:
C:/Xilinx/Vivado_HLS/2016.3/include/gmp.h:62:0: warning: "__GMP_LIBGMP_DLL" redefined [enabled by default]
C:/Xilinx/Vivado_HLS/2016.3/include/floating_point_v7_0_bitacc_cmodel.h:135:0: note: this is the location of the previous definition
from ../../../../thin.cpp:2:
Assertion failed: (_rows > 0) && (_rows <= ROWS) && (_cols > 0) && (_cols <= COLS) && "The number of rows and columns must be less than the template arguments.", file C:/Xilinx/Vivado_HLS/2016.3/include/hls/hls_video_core.h, line 600
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application's support team for more information.
@E Simulation failed: Function 'main' returns nonzero value '3'.
ERROR: [SIM 211-100] 'csim_design' failed: nonzero return value.
编译这个错误是什么回事?找不到原因。
0 项奖励
1 条回复
166 次查看
注册日期: ‎07-17-2008
回复: vivado hls 编译错误
看起来是用法问题。
你可以按照信息提示的,到安装目录下找到对应的文件,对照代码排查是哪里的行列设置超标。
0 项奖励
