sameer.al-obaidi
4DSP FMC150 High-Speed ADC/DAC FMC Module
Hi;
Why the sampling rate of  ADC LOWER THAN DAC.
250 MSPS Analog to Digital converter (ADC)
800 MSPS, 2x/4x interpolation Digital to Analog converter (DAC)
muzaffer
because DACs are easy and ADCs are hard so making a DAC go faster is easier than making an ADC sample faster. Also with a faster DAC, it is easier to generate the signal you want without extra analog filtering at the output.
muzaffer
