lilincon
A PROBLEM ABOUT THE master selectmap mode IN XC2V3000
Hi,i got a problem,its about the master selectmap mode,hope anyone can help.
Specific questions are as follows:
When I use master serial mode to configure the XC2V3000(prom is XCF16P) , the connection is referred to figure 4-8 of UG012 ,i connect the XCF16P D0, CCLK, CE, CF, OE/reset and FPGA Din, CCLK, DONE, PROG_B, INIT_B separately, and connect  FPGA PROG_B and INIT_B  with pull-up resistor.
In this pattern:
1,PROM configuration file is .Mcs format and is written in JTAG mode.
2, M0, M1, M2 mode selection is adjusted to 0, 0, 0.
it can configure successfully.
However, when I use the master selectmap mode, the connection is referred to figure 4-12 of UG012.
Based on the master serial mode
1, increased the connection of D1-D7 data interface, increased the connection of both BUSY pin;
2, the M0, M1, M2 mode adjusted to 1, 1, 0;
3,keep RDWR_B and CS_B low all the time;
4, the configuration file in PROM has no change, relative to the master serial mode.
At this point, you can't configure it successfully, so how do I do it to complete the configuration of the master selectmap mode?
