AC701 Development Board clock mapping
Hi everyone,
I am new to FPGA programming, and my team purchased an Artix 7 development board (xc7a200t-2fbg676) to experiment with. I have been bringing myself up to speed with various online tutorials, but I am now stuck when I have to connect a clock input in my UCF file. In all of the boards the tutorial authors use, it is as simple as adding:
NET "clk" LOC = A8;
or something similar. In the course of my research, I now know that the Artix 7 uses a differential clock involving two pins, instead of one clock pin. I have done my due diligence on Google and in these forums for the last three days, and I keep coming up dry. Can someone please explain to me how to connect the internal clock on the AC701 development board through the UCF?
Many thanks,
Grant
Tags (4)
I can't thank you enough for your help, Austin.
So that no one else has to spend the time I did scouring the internet for this information, I figure I'll post my solution for anyone else who wants to turn the differential clock into a single-input clock (without changing the frequency).
In the UCF file:
NET "CLK_P" LOC = "R3" | IOSTANDARD = "DIFF_SSTL15";
NET "CLK_N" LOC = "P3" | IOSTANDARD = "DIFF_SSTL15";
Then in my schematic file, I wired CLK_P and CLK_N into an IBUFGDS module, and then wired that into a BUFG module.
Voila, single-input clock exiting the BUFG module.
Thanks again, and I hope that helps someone else!
In the UCF file:
