sarit8
AXI4 driver for read and write functionaluty
I have to create a test for a design which incluse axi4 protocol.
I found a nice blog about a driver for axi (it focus on the write channels):
http://blog.verificationgentleman.com/2016/08/testing-uvm-drivers-part-2.html?showComment=1471877179631#c7809781639091671746
In this blog there is a use of SVUNIT library (which I am not familiar with).
Do you know another source of axi driver (handles with read and write channels)?
balkris
http://www.wiki.xilinx.com/DMA+Drivers+-+Soft+IPs
In case if you are looking for BFMs
http://www.xilinx.com/products/intellectual-property/do-axi-bfm.html
Thanks and Regards
Balkrishan
sarit8
There is no detail regarding the driver in the case of BFMS.
sarit8
There are no details regarding the driver in the BFMs.
p.s
I meant to driver of verification (UVM).
muzaffer
you can try this: https://github.com/muzafferkal/axi-bfm
