About fpga programming
Good morning all,
Please send me the verilog code for UART for fpga...............
Thank you
Vimala
Re: About fpga programming
Hello Vimala,
I think UART IP cores will help you.
Go through the following links:
http://www.xilinx.com/products/intellectual-property/axi_uart16550.html
http://www.xilinx.com/products/intellectual-property/axi_uartlite.html
Vinay
Thank you sir
Vimala
Hi Vimala,
Please close the thread by marking the solution.
Thanks,Vijay
Historian
Historian
@vimalab wrote:
Good morning all,
Here, Let Me Google That For You.
