miner_tom
Access to Xilinx Avionics developers Site
I am an electronics design engineer as well as an FAA certificated aircraft mechanic (A&P). A couple of months ago I submitted an application for access to the Xilinx Avionics developers site. I have received no response other than a notice that my request was received.
Is there another way to contact those working at Xilinx on the Avionics projects?
Thank You
Tom
anatoli
Hello @miner_tom ,
Have you hear back from the team on this yet? Have you gain access to the Xilinx Avionics developers site yet? Can you confirm on this please? Thanks
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
