Add IP definition to the catalog with vivado 2014.2
I have the next problem. I copy a IP block and this is locked. And to unlocked it I have to Add this IP block to the catalog.
Anyone can help me adding the IP to the catalog?
Thank you.
Have you created custom IP using IP packager?
Add that IP in your design using project settings -> Repository Manager.
Add repository path here to add IP in the IP catalog.
-Shreyas
Try to search answer for your issue in forums or xilinx user guides before you post a new thread.
Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query.
Give Kudos (star provided in right) to a post which you think is helpful and reply oriented.
