Ael
All my topics are marked as spam
I don't know why, but all my topics on the forum are directly marked as spam...
There is no reason, It is automatic because they are directly marked without delay.
For example, the following topic can't be read by all : https://forums.xilinx.com/t5/Memory-Interfaces-and-NoC/Quad-SPI-can-t-transmit-multiple-bytes/m-p/1260636#M20118
If a moderator read this, please whitelist my topic or explain me what I must do.
Thank you
florentw
HI @Ael
Using the report button is usually the correct solution. I have seen the message and unmarked the post. It should be visible now.
Florent
Ael
Thank you,
Could you tell me what should I do for not being marked ? Because it happens everytime I post a topic which is a bit long or with pictures.
florentw
HI @Ael
I am not sure what triggers the tool. For example this one was not marked.
There is a new community forums coming soon:
https://forums.xilinx.com/t5/Announcements/Our-New-Community-Is-Coming/td-p/1255188
I hope the spam detector will be better
Florent
