Analysis window
Is there a way to open an analysis window with the real cycles of the project instead the estimate cycles of synthesis..??
Advisor
Advisor
No. To do that, HLS would need to insert a debug core to trace every signal inside the block at runtime, which would take far more resources than the FPGA had available.
Apart from things outside of HLS's control (eg. congestion on the AXI buses, stream masters or slaves not being ready) the analysis displayed after synthesis should be correct. Are you seeing major differences?
Yes, at least two million cycles.
Synthesis export ~3500000 cycles for the whole project and cosim export ~1600000 cycles.
