dhalder72
Application project is not getting launched in SDK when invoked through VIVADO
Hello Everyone,
I have created a MicroBlaze based project on Vivado (version : 2015.4).
Target FPGA is Kintex 7 (XC7K325T-2FFG900C) and board is Digilent Gensys 2.
After implementation I did export hardware and launched SDK after bitstream through Vivado.
On SDK, I am not able to create application project.
No window appears if I click on application project.
Kindly let me know the solution.
Dhritiman
anm
Hi @dhalder72,
What version of the SDK are you using?
What Operating System are you using?
Check this also:
https://forums.xilinx.com/t5/Welcome-Join/Creating-application-project-at-SDK/m-p/744717#M42749
Kind regards,
Nassos
dhalder72
Hello Nassos,
The SDK version is 2015.4 and OS is Windows 7 Professional.
Also I am using administrative login.
I added the hdf file.
Dhritiman
