cjmaclean
Are systemverilog program blocks supported in vivado 14.4 design suite
Does vivado 14.4 design suite support program blocks? The following shows that Vivado is missing the required file test. Thanks
program test();
initial
begin
end
endprogram
module moduleTest();
test test1();
endmodule
vijayak
Hi @cjmaclean
The list of supported SV constcuts are given in Appendix D of http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_4/ug900-vivado-logic-simulation.pdf
Thanks,Vijay
muzaffer
program doesn't seem to be in the list of supported simulation constructs so it's probably not supported.
vijayak
Hi @cjmaclean
Thanks,Vijay
