Artix 7 DDR3 interfacing
I'm using XC7A200T-2FBG676 and have interfaced complete pins of Micron DDR3 (MT41J64M16TW-093) to bank 34 due to hardware design restrictions. Now according to the MIG controller, recommended banks where 34,33 and so on.
Now while using MIG IP it generate error showing some pins can't be used. Kindly let me know how MIG can be used if single bank can only be used for DDR3.
Bank 34 Voltage is 1.5V.
Check below AR
https://www.xilinx.com/support/answers/41752.html
Satish
Check below AR
Satish
Hi @bivin
What is the error you are facing?
Deepika.
Hi Satish
