kpench
Artix-7 FPGA DDR SDRAM support
Hi, We are planning to use the Artix - 7A50T device in our design with 1Gb DDR SDRAM memory support. Can you please clarify the below queries: 1. Does it requires any memory controller? 2. If so Soft IP needs to be purchasable or free of cost? 3. Please let us know logic resources utilization etc... Thanks Pench
vemulad
Hi @kpench
We have MIG IP (which is provided free with Vivado) but the 7 series MIG does not support DDR memory.
Please refer to this link http://www.xilinx.com/products/technology/memory-interfacing.html#7series
Deepika.
Deepika.
balkris
check this IP
http://www.xilinx.com/products/intellectual-property/1-8dyf-2908.html
Thanks and Regards
Balkrishan
vemulad
Hi @kpench
Deepika.
Deepika.
