vinod_1987
Aurora design example: #CDC file
        I'm using Aurora 8b/10b ip core on virtex 5 fpga, while creating *.CDC file, in select net window, i could see only top module. All other submodules are hidden. please find it in attachment 1.
when i run chipscope, (i tapped frame generator, Data), it showing only one generated data. what is the issue. please find it in attachment 2.
thank you.
venkata
Looks like the design hierarchy is flattened. I see the scroll bar is fairly long with several signals.
Check if setting keep_hierarchy attribute to "TRUE" can help for your purpose.
venkata
vinod_1987
Thank you.
