jacob.varghese
BPI FLASH Issue in Read
 I am trying to perform basic read/write operation in BPI Flash(PC28F00AP30TF) in KC705 evaluation board. I made use of xilinx example, initially write operation failed so I tired changing  START_ADDRESS  to 0X000000, write operation passed but when I am reading back I am getting valuea as 128 in my readbuffer.
Can anyone help me through this?
balkris
check this ARs
http://www.xilinx.com/support/answers/50079.html
Thanks and Regards
Balkrishan
jacob.varghese
Hello balkris,
 Can you go through my project. I dont understand it is not returning read/write fail when I am running the example c file I am struck not knowing where to debug. Please go through the code once and tell me if the parameter set is correct.
jacob.varghese
Hello balkris,
