12-26-2014 06:17 PM
Hi!
I want to make a simple PCI card to control stepper motor drivers, but for now, I wanted to start with something less complicated than PCI, so I wrote this module. creg [3:0] is a set of registers that can (should) be readable and writable from the dbus[7:0]. iowr causes dbus contents to be written to register selected by sel[1:0] on the raising edge of dclk. iord should read selected register to dbus, but it doesn't work :-( Of course I want my IC to stop driving the dbus (go to 8'hz) when clock goes low. m13 and m36 are example outputs that would drive other ics on my card (for example STEP/DIR signals for stepper drivers).
Module code:
`timescale 1ns / 1ps
module ftest1
input dclk,
input [1:0]sel,
input iowr,
input iord,
inout [7:0]dbus,
output m36,
output m13
reg [7:0]creg [3:0];
wire dbus_drv;
wire [7:0]dbus_out;
wire [7:0]dbus_in;
assign m13=creg[1][3];
assign m36=creg[3][6];
assign dbus_drv=dclk & iord & ~(iowr);
assign dbus=(dbus_drv==1'b1)?dbus_out:8'bz;
assign dbus_in=dbus;
assign dbus_out=creg[sel];
always@(posedge dclk)
begin
if(iowr) creg[sel]=dbus_in;
end
endmodule
What am I doing wrong?
I send my testbed code as attachment.
12-26-2014 08:25 PM
