Block RAM runtime data
I have couple of questions?
1) Is there a tcl script to log the entire memory content of Block RAM to a text file during behavioral simulation in Vivado?
Eg:
a tcl script which takes BRAM instance and a filename as argument writes the content of BRAM to the provided filename (say in coe format)
2) Is there a tcl script to initialize the contents of Block RAM during simulation?
I know .coe file can initialize before start of simulation. But I want to know if there is a way to load during run time through tcl script.
Eg:
run 100ns
<braminstance>.load(file1.coe)
run 50ns
<braminstance>.load(file2.coe)
Hi @sachiniisc
Please try the tcl commands mentioned in page 466, 999 of UG835:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_4/ug835-vivado-tcl-commands.pdf
Rohit
Rohit
@thakurr
You mentioned get_ips and set_param utilities. However which parameter of Block RAM IP corresponds to memory contents. I am unable to see this from IP documentation.
Hi @sachiniisc
Did you check the link i gave you in my last post? Page 466, 999 clearly mentions two commands:
generate_mem_files <directory>   This commands generates MEM files in the specified directory for use during simulation.
read_mem <files>     This command reads memory files of type MEM, DAT, or COE, and adds the files to the in-memory design, or the current project, to initialize BRAM memory for behavioral simulation, synthesis and post-synthesis simulation.
Please refer the below link :
Hope this helps.
Rohit
Rohit
@thakurr
First of all sorry I was looking at an earlier version of tcl command reference hence the confusion.
read_mem<files> is just adding coe file to the project. What I want is it to be loaded into the memory of a particular block ram instance during simulation. After running simulation for a fixed number of clock cycles, I want another coe file to be loaded to replace the memory contents and continue with the simulation.
Anything I am missing here?
Please note that I am not using any embedded processor based design.
