Build issue kali linux rootfs for zynq zc702: Unable to login
I am trying to port kali linux to xilinx zynq zc702 board as per the following link, with a difference that i want to use kali rootfs instead of ubuntu rootfs.
http://www.wiki.xilinx.com/Zynq-7000+AP+SoC+-+Installing+the+Ubuntu+Desktop+on+PetaLinux+and+Demo+Tech+Tip
I am directly using the precompiled boot partition given on the above link.
The boot partition contains BOOT.BIN, uImage & devicetree.dtb
Instead of using the linaro ubuntu rootfs,
I cross-compiled kali rootfs with the following script:
script.txt
But, I am unable to login to the system with default username/password: root/toor
Here is the serial console output.
Output.txt
Please help whether I need to modify kernel options or rootfs partition needs some extra configuration parameters. Is anything missing in the kali root file system?
Tags (4)
