Visitor sjh@notts
Building U-Boot for ZC706 fails on RHEL6
I am trying to build u-boot so I can use the tools to create a ramdisk image for the zc706 board.
I have downloaded the git as described in the 'fetch sources' wiki pages onto my Linux RHEL6 PC.
Performing the 'make zynq_zc706_config' command as detailed on the 'build u-boot' wiki pages seems OK.
However, when following with the simple 'make' command I get the following error:
[root@SJH-LX-DT u-boot-xlnx]# make
  CHK     include/config/uboot.release
  CHK     include/generated/version_autogenerated.h
  CHK     include/generated/timestamp_autogenerated.h
  UPD     include/generated/timestamp_autogenerated.h
  CC      lib/asm-offsets.s
lib/asm-offsets.c:1: error: bad value (armv5) for -march= switch
lib/asm-offsets.c:1: error: bad value (armv5) for -mtune= switch
make[1]: *** [lib/asm-offsets.s] Error 1
make: *** [prepare0] Error 2
[root@SJH-LX-DT u-boot-xlnx]# ^C
I notice that the config file created (.config) uses the value armv7, is this connected?
I have had a look through the various posts but can't find any reference to this error
Participant pete_128
Re: Building U-Boot for ZC706 fails on RHEL6
Do you set the CROSS_COMPILE environment variable?
I have this to build u-boot myself:
CROSS_COMPILE=arm-none-eabi- make -j8
Where I am building with arm-none-eabi-gcc. CROSS_COMPILE should be set to a GCC (but without the gcc at the end) visible on $PATH or you can just set it to a fully qualified absolute path. Sourcing the Vivado (SDK probably works too) settings64.sh, arm-xilinx-eabi- appears on my PATH so that might be a working value for you if you have SDK installed.
Visitor sjh@notts
thanks for that.
