Observer deepa_krishna
C\ RTL cosimulation result Interval NA in 2017.1
Hi Everyone,
I have a problem, while running the C\RTL co simulation in VIVADO HLS 2017.1.
I have successfully run my code in 2014 and 2016 version.
Can any one tell me why is the report NA only for interval??
-------------------------source code-----------------------------------
#include <stdio.h>
#include "ap_int.h"
void scounter ( volatile int delay, volatile int divider, volatile ap_int<4> *counter)
#pragma HLS INTERFACE ap_none register port=counter
#pragma HLS INTERFACE ap_none register port=delay
#pragma HLS INTERFACE ap_none register port=divider
#pragma HLS RESOURCE variable=delay core=AXI4LiteS metadata="-bus_bundle CONTROL_BUS"
#pragma HLS RESOURCE variable=divider core=AXI4LiteS metadata="-bus_bundle CONTROL_BUS"
#pragma HLS RESOURCE variable=return core=AXI4LiteS metadata="-bus_bundle CONTROL_BUS"
for (volatile int i = 1; i <= delay; i++)
*counter = i;
for (volatile int ii = 0; ii < divider; ii++);
return;
--------------------------Test bench------------------------------------
#include <stdio.h>
#include "ap_int.h"
void scounter(volatile int, volatile int, volatile ap_int<4> *);
int main ()
volatile int k=15;
volatile int j=5;
volatile ap_int<4> y;
scounter (k,j, &y);
return 0 ;
Re: C\ RTL cosimulation result Interval NA in 2017.1
Hi @deepa_krishna,
I guess this is because your values of divider and delay are not fixed. So the interval will depends on them.
If you fix them to a certain value (not input of the function), you should have a value for the interval.
Florent
Florent
I have set their values in test bench.
Do I have to increase their value??
Deepa Krishna
It is because of this warning I am unable to get it
While reading UG902, I relaised that the arbitary data types and volatile cannot be used together.
So i changed volatile ap_int<4> led* to ap_int<4> led*.
 But, then I am getting the below warning.
I even tried to change the interface to M_AXI and set the offset as slave. As I have defined the data type to be  4 bits. I am unable to use that interface.
WARNING: [RTGEN 206-101] Port 'led_V' with mode 'ap_none' may require an associated data valid signal to correctly communicate with other blocks or a test bench; automatic C/RTL co-simulation may not be able to verify such a port.
Please help me solving this warning
the arbitary data type and volatile can't be used together if an arithmetic operation is involved
