k@123
CAN ANY ONE HELP ME
I WANT TO CHECK DUC/DDC IP WORKING , SO HELP ME IN DESIGNING BLOCK DESIGN OF DUC/DDC USING ZYNQ7 FPGA
balkris
please generate the core from IP catalog . You can use demo testbench to simulate the core. Let me know if you stuck somewhere
check these document as well
https://www.xilinx.com/support/documentation/ip_documentation/duc_ddc_compiler/v3_0/pg147-duc-ddc-compiler.pdf
https://www.xilinx.com/support/documentation/application_notes/xapp1113.pdf
Thanks and Regards
Balkrishan
balkris
Thanks and Regards
Balkrishan
k@123
i m using vivado 15.1 is it avalible if so,where do i find demo test bench
balkris
Demo test bench will generate with core .
Thanks and Regards
Balkrishan
