madhub86
Can I use the IP core of an ISE in EDK?
I want to use the IP core of PCI express which is available in ISE in EDK, which means I should import all the verilog modules of ISE IP core to EDK. Is this possible, if possible please send related documents.
Thanks & Regards,
Madhu.B
vsrunga
Please check below links
https://sites.google.com/a/cs.ship.edu/fpga/xilinx-tricks/include-coregenerator-ip-in-edk
https://www.youtube.com/watch?v=j6GX9z-C2Us
http://forums.xilinx.com/t5/Embedded-Development-Tools/Coregen-files-in-custom-Pcore-User-Logic-Trouble-getting/td-p/67203
http://forums.xilinx.com/t5/Embedded-Development-Tools/Put-Coregen-component-into-EDK-library/td-p/20886
Hope this helps
-Vanitha
siktap
Yes you can.
http://www.xilinx.com/support/answers/22882.htm
Please check this. Hope this helps.
Sikta
balkris
Please find the attached document.
Thanks and Regards
Balkrishan
balkris
Below link may help you
Thanks and Regards
Balkrishan
balkris
you can check below ARs
http://www.xilinx.com/support/answers/37856.html
Thanks and Regards
Balkrishan
madhub86
I want to use IP core of ISE in EDK, the answer record you have provided is reverse. Can you please send if there is any AR related to my query. If possible please provide documents. My operating System is windows.
Madhu
madhub86
Thanks for the reply and for the link you have provided.
My query is in the last step you are able to view all the signals but in my project i am getting only below signals in .mhs file
BEGIN clk_50
PARAMETER INSTANCE = clk_50_0
PARAMETER HW_VER = 1.00.a
END
When i am trying to edit the .mhs file it is showing the following error
ERROR:EDK:4085 - IPNAME: clk_50, INSTANCE: clk_50_0 - PARAMETER CLKIN1_IN not found in the MPD - F:\pallani\ISE_EDK\system.mhs line 123
Can you please help me out to solve the issue
Madhu
madhub86
I have followed all the steps shown in the below link
http://forums.xilinx.com/xlnx/attachments/xlnx/NewUser/15250/1/coregen_clock_in_edk.pdf
BEGIN clk_50
END
Can you please help me out to solve this issue. please its urgent
Madhu
