aaronxupy
Can kintex7(xc7k325t) 's transceiver support 10GBASE-KR?
As the title, I hope to know whether kc7k325t support 10GBASE-KR.I didn't  find the 10GBASE-KR IP Core in vivado when I select the K7 series.
athandr
In the coregen in ISE you can find the supported devices for that core. Please check in that if the Kintex-7 is included in ISE. However from the notes it does not look like Kintex-7 is supported.
Anirudh
vuppala
Hi @aaronxupy
Check this pdf: http://www.xilinx.com/support/documentation/ip_documentation/ten_gig_eth_pcs_pma/v6_0/pg068-ten-gig-eth-pcs-pma.pdf (see LogiCORE IP Facts Table)
10G base-kr is not supported in Kintex 7 devices.
Vinay
aaronxupy
Hi vuppala,
             Thank for your reply. I can find the 10G base KR IP core in ISE when I choose the K7 series ,why vivado not?
smarell
Community Manager
Community Manager
10G base KR IP is supported only with devices that has GTH. All Kintex devices have GTX not GTH. Hence this core can't be used with Kintex.
I tried to see if there is any difference in ISE targeting KC705 and could see that this core is not supported.
Can you please share your configuration to reproduce this issue?
athandr
Anirudh
