Can not read RXCDR_CFG register in Artix-7
Dear sir
I try to read RXCDR_CFG register in Artix-7.
Unfortunately I can not for now.
Could someone can tell me the method of this?
Thank you.
Re: Can not read RXCDR_CFG register in Artix-7
I have solved this problem by myself.
Thank you.
Thank you.
Hi @go_jeff_huang,
Can you please post the solution here? As it will help other users in future with the same query.
Thanks a lot.
Prathik
Helpful answer -> Give Kudos
Hi prathikm
It was just my mistake.
I connected my DRP control circuit to GTPE2_COMMON port of my GTP IP core.
It was wrong.
After that, I connected my circuit to GTPE2_CHANNEL port, then I could read correct RXCDR_CFG register.
Thank you.
