jhouee
Can't log a ticket support
I still can't log a ticket under the portal !
I have all  browsers updates plus cache cleaned ...
I'll do more projects on 2016,  please help me to access this portal.
Johann
austin
j,
Please email me at austin@xilinx.com with your company name, etc.
I will pass that along to the support team to see if you qualify for webcase support.  Most support is through the forums (generally faster, too).
Austin Lesea
Principal Engineer
Xilinx San Jose
vijayak
Meanwhile post your issue here. We will try to address while your account issue is addressed.
Thanks,Vijay
vuppala
Hello @jhouee
You have access to Xilinx Service Portal. Can you share the snapshot of the error message when you are trying to login to Xilinx Service Portal (http://www.xilinx.com/support/service-portal.html)
Vinay
cperla
Hi @jhouee,
Your account should be fixed now. Please try logging in again.
Chris
jhouee
Thanks a lot !
